2008 rubicon build
Old 01-13-2012, 09:28 AM
  #121
Jeff76's Avatar
Got the Genright fuel cell that say is compatible with a Jk pump. It is but they don't tell you the pump has to be modified in several ways.
The wiring and rods have to be extended so the pickups can reach the bottom of the tank. The sending unit float arm has to be modified too. And then it's not going to be 100% accurate. It's more of a universal tank.
ID:	263454   Click image for larger version
Old 01-13-2012, 09:55 AM
  #122
CALIJK's Avatar
Originally Posted by Jeff76
Got the Genright fuel cell that say is compatible with a Jk pump. It is but they don't tell you the pump has to be modified in several ways. The wiring and rods have to be extended so the pickups can reach the bottom of the tank. The sending unit float arm has to be modified too. And then it's not going to be 100% accurate. It's more of a universal tank.
Thanks; I'm watching this closely because I have to figure out what to do with my fuel. Obviously, the old tank has to go. I know Genright has the JK repacement tank that mounts into the rear tub storage area, but I can't use that, because I'm pushing the rear axle back and that tank hangs too low. Also, I live in Cali, which has really tough emissions laws and I want my rig to stay street legal, so I need to make sure that I keep the evap can attached, etc. Anyway, good luck and keep posting pics.
Old 01-13-2012, 02:24 PM
  #123
Jeff76's Avatar
I'll post up a few pics of how I mod the pump to work with the Genright tank.
Old 01-14-2012, 01:08 PM
  #124
Jeff76's Avatar
What I had to do to make the stock Jk pump work in the Genright tank.
1. Get rid of the factory rods that hold the pump and housing together. I had to get the pump about 6" lower to sit at the bottom of the tank. I used stainless allthread, nuts, washers for this. Now pump pickups are directly against bottom of tank like they should be.
2. Factory fuel line fitting on top of plastic housing broke when removing the tank. I drilled it out and epoxied Barbed brass fitting in place.
3. Extend wiring that runs from pump to top of housing. I soldered these. This will have to be done for sending unit wires and fuel pump wires, 4 total.
Got it installed, had to cycle the pump on and off several times to get fuel through line to motor. Then it started up with no problem. Sounds pretty funny with the exhaust chopped off.
ID:	263873   Click image for larger version
ID:	263874   Click image for larger version
Old 01-14-2012, 01:18 PM
  #125
CALIJK's Avatar
Nice work on the pump. I've no doubt I will be making the same modification.
Old 01-14-2012, 04:00 PM
  #126
Jeff76's Avatar
Carolina Truggies can make you a custom tank with no pump mods necessary. It will be about $50 more and will take them 3-4 weeks to build.
Genright doesn't tell you that u need to mod your pump with this tank and you basically just figure it out on your own.
Or you can buy any cell and weld on a filler neck and pump ring to use the factory pump. I should have went this route. I could have saved a few hundred bucks. I spent more on the Genright tank because I was under the impression it was plug and play.
Old 01-14-2012, 07:16 PM
  #127
CALIJK's Avatar
Carolina Truggies can make you a custom tank with no pump mods necessary. It will be about $50 more and will take them 3-4 weeks to build. Genright doesn't tell you that u need to mod your pump with this tank and you basically just figure it out on your own. Or you can buy any cell and weld on a filler neck and pump ring to use the factory pump. I should have went this route. I could have saved a few hundred bucks. I spent more on the Genright tank because I was under the impression it was plug and play.
Thanks - I appreciate the heads-up! So, how long until your rig is ready for the trail?
Old 01-15-2012, 10:05 AM
  #128
Jeff76's Avatar
Still have front coilovers to do, hydraulic steering, brakes, driveshafts, exhaust.
Should be ready some time this spring.
Old 01-15-2012, 10:45 AM
  #129
dizk's Avatar
Just read this whole thread. Great work man! This thing looks awesome, I can only imagine how amazing it will be when it is done. Wish I had the skills the knowledge to do something like this myself. Keep up the good work!
Old 01-16-2012, 01:01 PM
  #130
Jeff76's Avatar
Thanks, it should be alot of fun if I ever get it finished and on the trail. I'm gonna try and make Moab next spring.
Quick Reply: 2008 rubicon build
