2008 rubicon build
Old 12-09-2011, 03:18 PM
  #101
kungfucracka's Avatar
Originally Posted by Jeff76
I'll be putting in a Chevrolet ls motor eventually. Gonna finish it and wheel it for a couple of years before I tear it down for a motor swap.
I see I see well either way that's one bad ass ride your making!
Old 12-14-2011, 02:45 PM
  #102
Dude you did anything else exciting?
Old 12-14-2011, 04:48 PM
  #103
Jeff76's Avatar
Got the front truss/hydro ram mount welded up, fitted and welded to the axle.
Had to make a few changes to get it to fit properly. Made for an older model ford 60 and mine is out of a late model super duty.
I may have to cut off the top of diff cover where it bolts to truss and design something different. I won't know till I get it back under the jeep and centered.
Truss came from btf.
ID:	250034   Click image for larger version
ID:	250035   Click image for larger version
Old 12-14-2011, 04:49 PM
  #104
Jeff76's Avatar
Upper links will mount to top of truss.
Old 12-17-2011, 04:56 AM
  #105
Jeff76's Avatar
How did my thread end up over here? I started in the builder/fabrication section.
Old 12-17-2011, 02:54 PM
  #106
saceone's Avatar
Awesome build man! So let's see.....
Fabbing skilz- check
Insane jk-check
Vette-check
I bet you married norvegian open to incestuous action twins????
Old 12-18-2011, 04:22 PM
  #107
Jeff76's Avatar
Insane jk-check
Vette-check
No, vette belongs to my gf. Its nice but I'm more of a 4x4 guy.
Old 12-18-2011, 04:29 PM
  #108
Jeff76's Avatar
In the process of designing my own high steer for a 2005 or newer bj Dana 60.
The knuckles don't offer much space on top for high steer arms. I cut off the old tie rod ends off the knuckles. Ground flat, then drilled and tapped for five 1/2" gr 8 bolts.
3/4" stubby high steer arms will weld to the 3/8" plate that mounts to the knuckle. Then a long gusset will run from underneath the arm back to the 3/8 plate.
Should be super strong.
ID:	251462   Click image for larger version
Old 12-18-2011, 06:22 PM
  #109
Schwheelz's Avatar
So Is your steering arm also a reinforcement to your knuckle?
Old 12-19-2011, 02:54 AM
  #110
Jeff76's Avatar
Not really. The arm will weld to that peice vs the knuckle that is made of cast steel.
Quick Reply: 2008 rubicon build
