2007 JK transfer case broke
I'm sorry to hear about this. I've been in the same place as well. Vibration in the front driveline seems to be causing the front half of the Tranfer case housing to crack. my front case half was cracked from the input shaft down to the bottom seam of the case. If caught early enough the front case half and the breather vent are the only parts needed to do the repair. if you don't notice the leaking oil then the case fails much like the OP's did.
I was able to find the crack after finding the puddle of oil under the jeep during a pit stop. when I did the repair the entire area around the bearings was spider webbed on the inside of the case.
Could you snap a pic of the front of your tcase? A point brought up previously is that the 07's have a harmonic doo-hicky thing on the front of the case that is supposed to help with the vibes. Just curious to know if you actually have it.
Found the thread, bottom of page 7
https://www.jk-forum.com/forums/show...bration+damper
The jeep has a 4' lift and Tom wood driveshafts in it (bought it from dealer lifted )and was looked over by the dealer that I bought it from, that also is the home of Blue Mountain jeep allance
Xfer case
What would front pinion angle have to do with a Tcase gernading on the highway?
If it was in 4WD I could see it and the answer is obvious, but I doubt very much he was in 4WD.
Just curious
Thanks
Just curious
Thanks
Just curious
Thanks
Just curious
Thanks
It has to do with whatever causes the front pinion angle to be more than a very few degrees, when there is a double cardan at the t-case. That double cardan requires the pinion angle to be as close to zero as you can get it.
If you get drive line vibes that get worse at highway speeds, it's a time bomb.
This is confusing (the pinion at 0 degrees). You want the pinion pointed towards the transfer case. A stock axle has 6 degrees angular separation between caster axis and pinion, my PR 44 has 10. I run 6.25 degrees caster and 3.75 degrees pointed up towards the transfer case. What you mean is as little angle as posible between pinion and driveshaft angle isn't it? With still enough caster that you don't wander all over the road.
That is the definition of pinion angle.
It would seem the aftermarket would pick up on this and figure it out. Why cant you convert the driveshaft flange into something similar to the crankcase vibration damper pulley? It seems Chrysler knows something about this transfer case that we dont. Why would they put a vibration damper on the rear driveshaft on a rzeppa joint? The true contstance velocity rzeppa should counteract any vibes from the single carden joint at the diff. The 2007 model had a vibration damper in the front, but stopped it looks like with the 2008 models and on.
