2007 JK build:longarms and 40s
Old 11-13-2013, 10:50 AM
Forum Tech Advisor
planman's Avatar
Is he going to off road it?
An unbraced drop pitman arm with 40s and no hydro assist will make quick work of destroying the stock steering box and sector shaft even without much time off road.
Dana 44s won't hold up a very long time to heavy offroading with 40s.
I did find that even with 3" net wheel backspacing--using Spidertrax spacers--I still had to buy longer bolts for steering stops.
With 6.75" lift, the front Tom Woods driveshaft will require backing off caster to 3 degrees or less with a stock axle that hasn't had the Cs rotated.
Rig looks awesome.
Taller than I'd do for out West wheeling, I run 40s on a 4.5" long arm with no body lift and plan to drop it to 3.5" springs soon.
Old 11-13-2013, 11:08 AM
Brett3xx's Avatar
mocking up the front bumper
We cut the frame horns back several inches and then rewelded the mounts. They are also higher to compensate for the body lift.
Old 11-13-2013, 11:14 AM
Brett3xx's Avatar
All the pieces tacked together, finally looking like a bumper
Cut the holes for the fog lights and Clevis mounts
Old 11-13-2013, 01:21 PM
finndogg's Avatar
looks really good man
Old 11-13-2013, 01:50 PM
ABENDX's Avatar
Who's the builder?
Originally Posted by jaker t5
So you actually have 7.25" lift , why such a big lift
LCG.... a fad that needs to be put to rest! Belly clearance is WAY too important to ignore.
Mine's sitting at about 10" on 40s and I have no feeling of instability.
Old 11-13-2013, 02:02 PM
v8zracer260z's Avatar
[/QUOTE]
Nice Work! Liking the front bumper!
Old 11-13-2013, 02:07 PM
Brett3xx's Avatar
Thanks
Originally Posted by ABENDX
Who's the builder?
I'm the builder, why?
Old 11-13-2013, 02:10 PM
Brett3xx's Avatar
Originally Posted by kh202
I like it. Could do other small things like d rings to match. One of those things that looks great in moderation. Full green exo cage would be pretty sweet tho lol
Yea, in moderation I think it looks good, I think it's a love it of hate it thing.
This is how he wanted it. He likes the height. It's still getting into the fender, so we're going to add taller bumpstops
Old 11-13-2013, 02:13 PM
Brett3xx's Avatar
Rig looks awesome.
It will see occasional off-roading. The sector shaft brace will be added in the future
Along with a draglink flip.
What kind of driveshaft problems will he run into with the caster at 4.5 degrees with the C's not being rotated?
Old 11-13-2013, 02:15 PM
ABENDX's Avatar
Mixing bolt on in... makes no sense that I can tell. Why?
Also... you are weak in plenty of other spots... PLANMAN was alluding to and will surely add to.
Ignore the height cops.... your build height is fine.
Quick Reply: 2007 JK build:longarms and 40s
