2.5" Teraflex with stock Rubicon tires...
I have it too. Stock rims, wheel spacers & 33's. I've wheeled it pretty hard... high rpm sandy hill climbs and slow crawl'n with lots of articulation.
No issues at all.
The axles are off, but hardly noticable. I would like to get adjustable track bars at some point.
No issues at all.
Simple geometry. Axle is connected to frame by track bar. Raise the frame, track bar goes up on frame end without changing the length of the track bar. Other end of the track bar at the axle goes to the side to compensate for the raising of the frame end.
glwood
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
Eternal ***erator
- You can prevent it from happening by not lifting the Jeep. If you lift it, it moves.
- Fixing it is done by getting aftermarket adjustable length track bars.
glwood
Eternal ***erator
Teraflex BB is due in today; I already ordered a rear track bar bracket from BDS that I read about, it came earlier this week. It is a very stout bracket, and it mounts on the FRAME end, not the axle. It will drop the frame end and make the bar more parallel to the axle as is stock...I am hoping that this will recenter the rear axle once lift goes on...if front is off noticeably, I will get an adjustable front trackbar...
glwood
glwood
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
