2.5" Teraflex coil lift installed......
Here are the before and after pics. The weather was crappy and had to take the pics in the garage. It leveled it out nicely and I am extremely happy with how it looks. Thanks Teraflex!!! Will post some better pics when I come back from Moab
Before:
After:
35"s are next!!!
Before:
After:
35"s are next!!!
Installed it myself and with the help of a friend. Was a pretty easy install. The back end took the longest to do. Not difficult, just time consuming. I'm using the stock track bar for now. If you have the time and the tools and don't want to spend the extra money on labor, I highly recommend doing this lift yourself. I love it!
Looks good! I just put the same kit on mine last weekend and I absolutely love it. I threw on the 1.5" Spidertrax spacers since I'm running the stock tires to for now. Great kit- awesome look, awesome ride, awesome performance.
How did your rear track bar frame bracket work out? Mine, to say it bluntly, was a bitch. Only hiccup through the whole deal. Wound up welding it on the next day along with the bolts for backup.
The track bar bracket ended up being the most time consuming part of the install. I burned through 3 drill bits before I got the hole needed to mount that bracket. Then had to tap on the bottom of it a few times to get the holes to line up. Once I was able to get the bolts through, it mounted up with no problems. I took it wheelin' yesterday to test everything out. Everything is good and no problems off road or on the highway. I love the ride and the performance is great.
