2.5 Teraflex with 1" spacer
Does anyone have a side pic of their Rubicon with both the 2.5 Teraflex spring lift AND 1.0 spring spacer up front? I have both in mine and it almost looks as though the front end sets a little bit higher than the rear, this is with steel bumpers front and rear with a winch up front. I'm wondering if I should pull the spacer out or wait a while to see if the front settles down a bit. I've had the lift on for about 500 miles. Thanks!
500 miles? it has settled. I have an ARB in front with TF coils and it sits perfectly level. Don't expect much droop from a winch. If anything put a puck on the rear coils.... more lift and level
I know that I am running the 2.5" with a 1" spacer up front, and with an AEV bumper and winch the front "looks" a bit high when just looking at the flares, but when you measure at the frame rail I have about 1/4" of rake towards the front.
Thanks for the replies guys! Yep HG07JKRubi, that's just about what mine looks like (except I have 2 doors less))). I've measured my rock rails and it's about 1/4 inch higher in the front. Just looks quite a bit more when you look at the difference between the flares.
This is good to see. I have a TF 2.5 puck lift + another 3/4" puck on top of that. I have Mopar steel front bumper and a winch. Mine still sags a bit.
I was going to get TF 3" springs, but the 2.5" springs + 3/4 spacer looks perfect.
When I removed my hard top the rake gets even worse. Yours sits level with no top. That is what I'm going for.
Sweetness!
Sweetness!
