15 inch wheels
Old 02-06-2010, 06:08 PM
Marcin's Avatar
I just want to ask a question....
Do the rotors and brake caliper fit inside 15" rim without rubbing ?
Old 02-10-2010, 12:51 PM
Former Member
1230frstap's Avatar
check out the thread, which I believe is located here
http://www.jk-forum.mobi/showthread.php?t=94709
If not, there is absolutely a thread on this, so search away!
Old 02-10-2010, 05:06 PM
07crawler's Avatar
I will let you know if Black Rock 909's fit on Monday
Old 02-10-2010, 07:30 PM
TREDpunk's Avatar
Excellent, will be good to know, I'm looking at those Black Rock's as well!
Old 12-05-2010, 04:54 PM
florida jeeper's Avatar
Cool I love my 15 inch rims
A lot of places said it can't be done... 15 inch rims on a JK. Ha .... I told them to order them anyways. And I put them on and showed them. That was 4wheel parts and a couple of smaller 4x4 shops. So I like them because they make the JK look more Balanced. It actually drives more stable. Check out my pics.
Old 12-05-2010, 05:38 PM
JKRVEE's Avatar
I agree. I run 15" wheels and 35" MTRs and love it! Plus the tires are 218.00 for 15" and 340.00 for the 17"
Old 12-05-2010, 05:40 PM
h1ker's Avatar
Originally Posted by Rubi 2sday
Be careful, a lot of 15's will rub the brake calipers on JKs, which requires you to do a little grinding.
x2 if the backspace isnt right that will happen
Old 12-05-2010, 06:00 PM
JK-XS's Avatar
I'm considering 15s whenever I get new rims because a taller sidewall means my new rims won't get all jacked up and scratched on the rocks like my stock rims.
Old 12-05-2010, 06:06 PM
jcs07jk's Avatar
I have 15's and my wheels are still all rock bashed all over. Had to grind just a little off the back of the wheel to fit without hitting
Old 12-05-2010, 06:25 PM
Harbourone's Avatar
Wrong. It's all about poor qc and unacceptable tolerances at the plants that made the jk. The casting is thicker on some then others. Also punched steel wheels work less often due to the lip from the punch. Cast wheels are more likely to fit.
Quick Reply: 15 inch wheels
