03HDFB's 2011 Sahara Project 6 Sp
Old 02-08-2012, 07:10 AM
  #71
03HDFB's Avatar
Originally Posted by 1BAMFR
Sounds like all you have left is some datalogging...pretty simple...im swapping motors and the turbo this month....reworking the fuel system and a fresh dyno tune. Hahahahaha
AWE Man.......You do have some work ahead yet!! Yeah, Little tuning on my rig, A little assembly and tuning on Allen's....and we are ready!!
Don't forget the vids and send me the link!
G
Old 03-11-2012, 10:57 AM
  #72
03HDFB's Avatar
Default Updated Build Listing!
I Updated My Build Listing in Post #49
Suspension:
4” Supper Lift
Brakes:
Stainless Steel Brake Line Extensions
Engine Dressing and Performance:
Diablo Intune Tuner
Coming Soon…..Prodigy Jeep Turbo Kit
Transmission (NSG-370 and NV-241 Trans Case) / Differential (Dana30 Front, Dana 44 Rear) :
J.E. Real 1350 CV Front Drive Line
J.E. Reel 1350 CV Rear Drive Line
Exterior Mods:
BFXenon HID Headlight Conversion Kit 6000k 35 Watt
BFXenon HID Foglight Conversion Kit 6000K 35 Watt
Warn Elite Front Winch Bumper and Grill Guard
- 7” HIDX Offroad Lights 6000K 35 Watt (Removed PIAA's)
- Warn VR 10,000 K Winch
- 100 Ft Nylon Rope
- Warn Billet Fair Lead
- Warn Remote Winch Control Unit
- Warn Deluxe Winch Recovery Kit In Rugged Ridge Tire Swing Bag
- Rugged Ridge ľ” Stainless D-Rings
Windshield Offroad Lights
- HIDX Windshield Light Brackets
Rugged Ridge XHD Rear Bumper
- Frenched In Warn 2”x3” Fog Lights
- Rugged Ridge Spare Tire Swing
- Rugged Ridge Spare Tire Swing To Tailgate Linkage
- Rugged Ridge Rear Bumper Stainless Steel D-Ring Assemblies
Frame Rail Lighting
- (2) ANZO Stealth Vision 3”x5” LED Fog Light Assemblies
Garvin Track Rack 48x42x4
- Garvin Sport Rack wind deflector
Star Fab Smart Door Stops (Front)
Star Fab Smart Door Stops (Rear)
Mopar Stainless Steel Entry Guards Front and Rear
Mopar Chrome Fuel Door
Drake Billet Front Grill Insert Kit
AMI 6” Billet Stubbie Antenna
Passenger Side Trail Rated Badge
- All Other Sticker Removed!
Interior Mods:
Off Road Eng. LLC (6) Channel Switch Panel Assembly
- Custom Fabricated Factory Consol Bracket
Rugged Ridge Rocker Switch A Pillar Plate
- Modified to House (2) 2-1/16 “ Gauges
- Zeitronix ZT-2 Module and ZR-2 Multi Gauge
-(AFR's, Boost, Fuel Pressure, ETG's,Lambda Etc.)
- Aeroforce Interceptor Gauge
Rugged Ridge UPR Roof Rack/Consol
- Modified to House a CB
(6) Mopar Grab Handles
Stereo / Communications Mods:
Midland 1001 LWX CB
Duel Fire Stick Antenna Kit
- Tailgate mounted with Taraflex Mount
Wheels and Tire Mods:
(5) 295 x 70 x 18 Nitto Grappler M/T’s
(5) 18 x 9 MHT Hostage 531’s (Chrome)
Security:
Lo-Jack Auto Security System
Its Turbo Time!!!!!
G
Old 03-22-2012, 08:05 AM
  #73
03HDFB's Avatar
Default Update....Prodigy Turbo Delivery!
Little Update...Just took Shipment of the Prodigy Turbo Kit.
I Didn't have mush time lastnight, but I did break everything
out of the Boxes.....Very Nice Kit!!! I hope to get working on the install
next week....I'm gona work my gauge package install and sensor locations first
and perhaps finish modifying that Hyline Front Air Dam to fit my Warn Elite Bumper!
G
Old 03-29-2012, 06:13 AM
  #74
03HDFB's Avatar
Default Update.....Install Progress!
Sorry So Slow Guy's,
All is Well.....I'm about 4.5 hours into the install and basicly done!!! Although I'm waiting for Forever Powder coat to finish the Ceramic on the down tube
and the Powder coat on the charge tube. Once I get them back....I'm about 30 Min from turn key!!! Lastnight I dropped the Oil pan and install an AN fitting
for the oil return from the Turbo, Installed the Turbo Oil Feed Line....The Motor already has a spot for this. Swapped the Plugs, Ripped off the Intake
and installed some added Sensor for my Zeitronox Wide Band System (Boost,AFR, Lambda, IAT at the back of the intake, Fuel Pressure at the rails) I had to install another Bung
in the Exhaust for my O2 sensor for the AFR. Installed the new Injectors and put everthing back together....Topped off the oil! After that I worked a little on my Gauge Pod.
I ordered a Rugged Ridge A-Pillar switch pod without switches ($29.00)......Layed Out and Installed My Aeroforce Interceptor and Zeitronix gauges......Nice fit...Cheep sweet
looking pod. I'll post up some pics and Vids soon. The System is well thoughtout and very easy to install. With no Parasitic HP loss.....the system should perform sweet!!
G
Old 04-14-2012, 08:08 AM
  #75
03HDFB's Avatar
Default Update.....Factory Dyno Pull
Finally Getting some time to get caught up!!!
Here's a Quick vid of the Factory Dyno pull (My Base Line)
My Jeep was putting down 147 RWHP and 171 RWTQ
Running 34.5" Nitto's and 3.73 Gear on my Factory 6 speed
http://www.youtube.com/watch?feature..._bOy4XRlipGxUg
Old 04-14-2012, 08:31 AM
  #76
03HDFB's Avatar
Default Update....PIcs of Prodigy Turbo Installed PLus Modified Hyline Front Vailance!
So,
Here's Some Pics Of the Prodigy Turbo Kit Installed. I had The Down Tube and Charge Tube Coated....Ceramic on the Down Tube and Powder On Tha Charge.
In All....Even with some of the extras I did for Tune Data Collection.....It took me about 6.5 hours to install. The Kit is very well thoughtout.....Every thing you need for
install is in the kit.....and top of the line hardware to boot!!! The Installation manual was easy to follow and the pics were great!! With my Jeep being a 2011.....I had
to install the Prodigy Perfromance PCM.....Flawless!!! As far As I can tell...the "Out Of The Box" tune is spot on......I'll know more once I Dyno again. I managed to put 1000 miles
on the Jeep since install and everything is working flawlessly!!! THe power is Killer and rolls on very smoothly. I now have the use of 6th gear again....It was about useless with my
factory gears and 35's. Now I can roll onto the throttle and pass at will....Or drop a gear and move out like many sports cars!! I couldn't be happier and since the Jeep is my Wifes
Daily Driver.....nothing but smiles from Her as well!!! I'll post up the Turbo Installed Dyno pulls...as soon as I can get to the drums.
Here's Some Pics
Here's My $29.00 A Pillar Gauge Pod.... I used a Rugged Ridge Switch Panel
Here's My Hyline Front Bumper Vailance.....That I Modified to Fit the Warn Elite Bumper
Here's a Quick Walk Around and First Start Vid!
Old 04-21-2012, 05:28 AM
  #77
03HDFB's Avatar
Default Update....Prodigy Turbo 1st Dyno, 87 Octane on Mustang Dyno
Alright,
So, My lady was helping me out the night before dyno day and filled the Jeep With 87 Octane Fuel......That's about 70.00 and a whole Lotta pumping to remove.
I stuck with my original Dyno date.....Its such a pain this time of year to find any open Dyno's....So I went in with data collection in mind.
The Tune was pretty close right out of the box...Little lean for my area! I sent the Data Off to Prodigy Performance....and Wes is blowing thru it and making adjustments
Here's The Data right Now:
Mustang Dyno, 3.73 Gear, 35" Tires 4th Gear Pulls
1st Pull: 236 RWHP and 265 RWTQ , 8 PSI, 87 Octane Fuel
2011 Jeep Wrangler Prodigy Turbo Kit 8PSI Pull 1 - YouTube
2nd Pull : 240 RWHP and 270 RWTQ , 8 PSI, 87 Octane Fuel
Watch the Front End Lift!!! Gotta Love that!!!
2011 Jeep Wrangler With Prodigy Turbo 8PSI Pull 2 - YouTube
I'm Gona work thru the Tune with Wes....And hit the Dyno again with Some 92 Octane!
G
Old 07-28-2012, 04:12 PM
  #78
Medanr's Avatar
You need to check out crazy house customs on YouTube. Reference Crazy House Customs prodigy turbo. It's a great comparison of Ripp and prodigy power.
Old 07-31-2012, 07:20 AM
  #79
03HDFB's Avatar
Yeah...Sweet Vid!!! I wouldn't have done my Jeep any other way...Free HP, As green as it gets and the most minimal maint!!
Old 08-21-2012, 07:41 AM
  #80
03HDFB's Avatar
Default Update...New Wheels, Hi-Lift Jack and SRT6 Turbo Badges
Well,
Still too busy with Race Season and Car Shows to get much done on the Jeep!
I did get the wheels swapped, MAde a bracket for my Hi-Lift Jack and Installed and
Had some Street and Rough Trail (SRT6) Turbo Badges made....and Put them on Lastnight!
Quick Reply: 03HDFB's 2011 Sahara Project 6 Sp
