Trail Tools?
Most socket sets and an assortment of wrenches will get the job done . However a couple that are not included in most sets are a 8mm 12 point wrench and socket for removing your driveshaft. Also a 36mm socket, 13mm 12 point wrench and socket to remove your front axle shafts.
Here is my trail tool kit
I put this together for just under a $100. Everything fits into a tool bag that goes right under a rear seat.
http://www.youtube.com/watch?v=mvEhOLgbLu0&feature=share&list=UUXTZFmxzXoJ9Fa2Bj6X3clg
I take a lot of tools on the trail with me. At least that's what I'm told.
It's basically a craftsman mechanics kit, 3 bags and two craftsman wrench kits. I also take a large bin with every fluid the Jeep would need, a small bin for electric and other misc stuff and my ARB recovery bag will all my straps, shackles, etc. All that takes up about 75% of the trunk area in my unlimted. Plenty of room left for clothes, food etc.
Tools:
Socket bag:
Impact
1/2" Deep - 12, 13, 14, 15, 16, 17, 18, 19, 21, 22, 24, and 27mm
1/2" Deep - 3/8,7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16
1/2" 6" extension
1/2" 3" extension
Non-Impact
1/2" not-Deep - 27,28,29,30,32,36mm
3/8" Deep - 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8
3/8" Deep - 10, 12, 13, 14, 15, 16, 17, 18, 19mm
3/8" not-dDeep - 10, 12, 13, 14, 15, 16, 17, 18, 19mm
Hex
3/8" - 5/32, 3/16, 7/32, 1/4, 5/16, 3/8
3/8" - 4, 5, 6, 7, 8, 10mm
Torx 3/8
3/8" - T40, T45, T47, T50, T55, T60
1/2" - 12" breaker bar
3/8" - 6" extension
3/8" - 10" extention
Wrench bag:
Black roll:
Combination wrench - 8, 9, 10, 11, 12, 13, 14, 15, 16
Green roll #1:
Locking Flex Ratcheting - 8, 10, 12, 13, 15, 17 and 19 mm
Locking Flex Ratcheting - 5/16, 3/8, 7/16, 1/2, 9/16, 5/8 and 3/4 inch
Green roll #2
Combination wrench - 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 3/4, 7/8, 15/16
10-75 ft.-lbs. 3/8" torque wrench
Combination Wrench 12pt - 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, and 1-1/8 in.
Needle nose
Medium channel lock
Large channel lock
Large crescent
Wrench kit(s):
Regular - 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, and 22mm
midget - 4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, and 11mm
Regular - 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8, 15/16, 1, 1-1/16, and 1-1/8 in.
Midget - 13/64, 15/64, 5/32, 3/16, 7/32, 1/4, 9/32, 5/16, 3/8, and 7/16 in.
Craftsman kit:
Sockets:
(11) 6 pt. 1/4 in. Drive standard sockets (5/32, 3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16 in.)
(12) 6 pt. 1/4 in. Drive metric sockets (4, 5, 5.5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm)
(10) 12 pt. 1/4 in. Drive standard sockets (3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16 in.)
(10) 6 pt. 1/4 in. Drive deep standard sockets (3/16, 7/32, 1/4, 9/32, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16 in.)
(11) 6 pt. 1/4 in. Drive deep metric sockets (4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14mm)
(5) 12 pt. 1/4 in. Drive deep standard sockets (1/4, 9/32, 5/16, 11/32, 3/8 in.)
(11) 6 pt. 3/8 in. Drive standard sockets (1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, 7/8 in.)
(13) 6 pt. 3/8 in. Drive metric sockets (6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18mm)
(9) 12 pt. 3/8 in. Drive standard sockets (1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4 in.)
(10) 12 pt. 3/8 in. Drive metric sockets (8, 9, 10, 11, 12, 13, 14, 15, 16, 17mm)
(6) 12 pt. 3/8 in. Drive deep standard sockets (3/8, 7/16, 1/2, 9/16, 5/8, 3/4 in.)
(6) 12 pt. 3/8 in. Drive deep metric sockets (9, 10, 12, 13, 14, 15mm)
(7) 6 pt. 1/2 in. Drive standard sockets (3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4 in.)
(7) 6 pt. 1/2 in. Drive metric sockets (13, 14, 15, 16, 17, 18, 19mm)
Combination wrenches:
(5) Standard (5/16, 3/8, 7/16, 1/2, 9/16 in.)
(5) Metric (10, 11, 12, 13, 15mm)
Extension bars:
(1) 3/8 in. Drive (3 in.)
Ratchet:
1/4, 3/8 and 1/2 in.
Magnetic handle:
9 pc. Screwdriver bit set
12 pc. Nutdriver bit set
20 pc. Standard hex key set
20 pc. Metric hex key set
Misc. Tools:
3 lb sledge
Rubber mallot
Dewalt 1/2" 18v impact wrench
25-150 ft.-lbs. 1/2" torque wrench
Breaker back from floor jack
Tools:
Socket bag:
Impact
1/2" 6" extension
1/2" 3" extension
Non-Impact
Hex
Torx 3/8
3/8" - 6" extension
Wrench bag:
Black roll:
Green roll #1:
Green roll #2
Needle nose
Medium channel lock
Large channel lock
Large crescent
Wrench kit(s):
Craftsman kit:
Sockets:
Extension bars:
Ratchet:
Magnetic handle:
Misc. Tools:
3 lb sledge
Rubber mallot
Where did you get the tool rolls? I'm pretty well packed except for my wrenches...
He's my list...
The bulk of it is just for trail runs, the go bag is just my anal retentive attempt to be prepared, it's two days worth of whatever you can think of to get by for two days of last minute travel or even just being prepared in case of rapid weather changes, or falling down in the mud!
Always looking for suggestions on things I overlooked, all of the stuff below fits in a moderately sized Hardigg case (kind of like a bigger version of a pelican case)
Except for 48 hour go bag everything is strapped down to the factory mounts meant for back seat in 2 door jk, using ATV ratchet straps
Packing inside Jeep
Bare basics...maglight d cell flashlight with extra batteries, Rigid Industries small deathly bright flashlight, leatherman, 48 hour go bag, Allen wrench and regular wrench both for Ace hood mount for hi lift jack...
Spare remote for winch always kept rolled up under passenger seat (winch is unusable without corded remote and primary remote is kept in ARB rescue bag that's only loaded in Jeep for trail riding etc)
(optional based on locale Glock .40)
Tan case
Wrenches standard and metric
Socket wrenches std and metric
Allen wrenches stndrd & metric
Torx sockets!
Green screwdriver set
Tiny screwdriver set
Red Pliers, needle nose & regular
CB Radio
Electrical
Fuses
Simple 12v testor
Multimeter
Electrical tape
Jumper cables
Basic wire strippers
Wire cutters
Repair - Quick fixes
Jumbo zip ties
Smaller zip ties
Bailing wire
Tire repair kit, spare tire stems
Fix-a-flat
Radiator liquid patch
WD 40, PB Blaster
Gorilla tape, silicone rescue tape
Short 2x4
Rubber mallet
Vehicle Fluids
5/w/30 jug
Brake fluid
Water 2 gallons
(Need to add more stuff to this list)
Recovery Kit (dedicated ARB bag)
Winch remote
Rescue strap
Tree hugger
Spare D-shackle
Gloves
Folding shovel
Nitrile gloves - first aid kit
Tool box
Orange bucket
Air Compressor (dedicated bag+box)
12v cable & clamps
Air hose w/inflation head
TeraFlex Deflator
Go Pro - Hard case & pb pouch
3 cams
10 charged batteries
2 external extra batteries
1 LCD backpack
Clear cases
Labeled back doors
Lots of chips
Fine tether line!!
Micro carabiners
Spare mounting feet
Tested USB power cable
12v cigarette power tap
Flat & curved sticky mounts
Dental floss
Comfort items
Hand cleaning wipes
Toilet paper
Nitrile gloves
Change of socks
Rain gear (jacket, pants, boots
Towel(s)
Ponchos
Go Bag (48 hour + weather)
Good rain coat
Pair of jeans
Socks wool & cotton
Underwear
T-shirts
Long sleeve shirt
Sweat pants
Sweat shirt
Shorts
2 days meds + OTC basics
Pair of contacts & drops
Pair of rx glasses
Hats - baseball & winter
Bare minimum toiletries
Portable pillow
Bean boots
