JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
rust on frame?
Old 09-24-2013 | 04:43 PM
Jeek.OlllllllO's Avatar
Originally Posted by familytime
We touch up the underside once a year
Yeah my dad was getting mad yesterday because it looks bad down there lol
Old 09-25-2013 | 06:39 PM
Dahmer's Avatar
Try some por15 or chassis saver you will never rust again. It is pretty much some of the toughest paint on the planet.
Old 09-25-2013 | 06:42 PM
Dude might be the toughest paint out there but if you wheel on rocks its not going to stop it
Old 09-25-2013 | 06:46 PM
k0260's Avatar
Another rustoleum or rust x user here. Touch up when/where needed call it good.
Old 09-25-2013 | 06:52 PM
Yeah that's what I plan in doing just so my frame doesn't get eaten up by rust.
Old 09-25-2013 | 06:59 PM
Dahmer's Avatar
You might want to check it out it bonds to the metal much like powder coat. I rammed a bumper into a rock bending the bumper and didn't even chip the paint. I pained some axles on a bronco and drag them over rocks still looks new. You may chip some of it off but it is 1000 times better than paint. Spray paint does good to stay on a year without rusting in normal conditions. Yeah spray paint is cheap but who wants to paint every year when you could just on the occasion do a touch up. It cures using moisture so if it gets wet it gets harder completely sealing the metal from rust. Notice the picture the frame was painted with spray paint the same time the axle was painted with chassis saver.
Old 09-25-2013 | 07:07 PM
Hmm I might have to check it out! Thanks! But not in my budget right now
Old 09-25-2013 | 07:20 PM
Dahmer's Avatar
Yeah its pricy I usually by the small can and do a small project at a time. Notice I only painted the axles on the bronco.
Old 09-25-2013 | 08:39 PM
Benm1020's Avatar
Former Member
Yea I have to coat my frame every year with Bedliner bc of the salt road winters and in the summer on an island, preventable maintenance is a lot better than a frame collapsing due to rust
Old 09-29-2013 | 07:28 AM
O7/RubJk*'s Avatar
Default Rust
Well i clean everything first. Remove any oil, grease. Then i use diffrent wire brushes and i apply a rust converter that neutralize the rust and leaves a surface ready to be painted. For paint i use POR-15. Is a good product, and it comes in satin, flat or gloss. Try and check online Eastwood.com. for
Good luck!
Quick Reply: rust on frame?
