RK sway bar links on Rubicon
#21
Well, here we go. I doubt my end links were too short. They were 13 degrees above parallel to the ground. That should be plenty. Heres what happened after not disconnecting. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=623850"/>
I usualy always disconnect manually. But today I went out with a friend in a little TJ and didnt expect anything big. The only reason this happened was I needed to find a new FB picture so I went and found a large rock to flex on, and I forgot I still had my end links on. So, longer links, using the e-disco, you can surely twist em up.
