JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Really Stupid!
Old 04-05-2009 | 10:19 PM
biglynny's Avatar
None. Nada. Nyet. You're ok.
Old 04-06-2009 | 07:57 AM
packrat213's Avatar
When we get snow I usually drive in 4HI never had any problems.
Old 04-06-2009 | 08:04 AM
knyland's Avatar
you will be fine just dont make a habit out of it.
Old 04-06-2009 | 08:16 AM
robin's Avatar
all of the above!!!
Old 04-06-2009 | 08:41 AM
4x4jkx's Avatar
One time... you should be fine. Since nothing was binding until you turned into your driveway the most "damage" you could have done would have been at that point. Just don't go over 55 again in 4hi
Old 04-06-2009 | 10:11 AM
TheonlyREDhead 2008 JK's Avatar
Sounds like something I would do
Red
Old 04-06-2009 | 11:13 AM
IMFletch's Avatar
it's no big deal. Just don't make a habit of running the drive train in 4wd on dry pavement at hwy speeds.
Old 04-10-2009 | 03:47 AM
Deere_Jeep's Avatar
Your all good. No more beer after trail riding for you.
Old 04-10-2009 | 04:58 AM
jeeperjkj's Avatar
Originally Posted by tambil68
just so new people get this right.
Your front and rear tires will turn at the same rate.
It's when you turn a corner, that the inner tire has less distance to travel but the 4x4 is trying to turn both passenger and driver tire at the same speed, even though it requires a different speed so they can travel different distances in the same amount of time. Same thing would happen if you had a full rear locker locked and tried to turn a corner on pavement.
I'm gonna have to disagree.
The only way you would get binding on tires on the same axle is if you had a locker or really good LSD in the diff. If it's open, then it won't bind 'cause the diff will let one wheel spin faster than the other.
The bind you get from driving in 4x4 on dry ground is from your front & rear wheels trying to turn at the same speed, right...
Old 04-10-2009 | 06:08 AM
Muffins's Avatar
No big deal at all, just wouldn't make a habit of it, I've gone a lot faster than 70mph with my F-350 in 4hi, never had an issue
Quick Reply: Really Stupid!
