JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Need help
Old 12-30-2013 | 12:52 PM
bhealy's Avatar
Default Need help
Took my 2011 jk unlimited off roading and got bogged down pretty deep. Cleaned off all the mud or as best as I could and I got an alignment and re entered the wheel. I currently have abs when I slam on the brakes however my abs light, tc light remain on as well as hill assist blinks when I first start my jeep. I checked the sensors and from What I can tell they're not caked with mud. Once in a blue moon the remote start will die for no reason and it has started since mudding. I tried running the codes however it is throwing no codes. Looking for any possibilities before replacing the abs sensors
Thanks
Old 12-31-2013 | 05:42 PM
gunbo75's Avatar
Try this first disconnect the battery for a little while and then reconnect it. Good luck
Old 01-02-2014 | 04:59 AM
bhealy's Avatar
Tried it light is still on :(
Old 01-22-2014 | 09:02 AM
Smithman190's Avatar
Same thing happened to me, one of the rear wheel sensor went bad due to mudding, had it replaced and it fixed my problem. I think it was about $25 for part.
Quick Reply: Need help
