MUD'ng and 4W??
OP, you will find out very quickly what works and what doesn't. If you look at these guys signatures telling you 4 hi, you will notice most of them are rubis with 4.10's. You have 3.21 gears and a six speed. Trust me that is not enough gear and you will wind up burning out your clutch, but you will find that out as soon as you get into it. I have found with my 3.21's and 32's, I can't do anything offroad in 4hi. But in mud try 4lo 2nd gear. Works pretty good. And watch peoples sigs to see what gears they have before taking their advice.
Once again though, you will find out for yourself when you do it! Hurry up get it muddy and report!!!!!!!
The higher gears (lower numerically) will give you less torque at the wheels and hence less traction. That will cause you to spin more readily. That'll affect your ability on more dificult trails.
The people that are talking about using 4 LO are probably talking about little mud puddles and not mud bogs which is typical of "going mudding". Years ago I lived in Minnesota and pretty much the only thing there is mud and deep water. Torque doesn't help that much in those bogs, because you're not likely to reach the bottom of the mud before you high center. What helps is paddling your way through the mud and keeping the belly above the mud with speed. The only way you can do that without specialized tires is for them to self clean. The only way for them to self clean is to spin them. The only way to safely spin them is to be in 4HI (high speed/high RPM is tough on the transfer case in 4 LO from what I've read).
I've done mudding with a few different vehicles including a TJ and a pickup, so the poster that said don't listen to the guy with a Rubicon is incorrect about that. As for the effects on the clutch I cannot comment, because I've always used automatics offroad.
Excellent responses guys...Thanks! The above quote though kind of worried me BIT...I'm totally new to off-road'n and I thought my new "X", with 3:21 ratio would really be enough to do some good off-roading? I mean, I'm not going rock crawling but at least some fun trails and such...Is 3:21 with a 6spd really not going to cut it? I'm in Texas so snow and ice aren't a concern to me and I wouldn't need 3:21 if it's only for highway and slippery conditions...Anyone chime in who has 3:21 tell me if I'll be good enough out there??
Also, remember that you can start the jeep without pushing in the clutch in 4LO.
Oh, and if you havn't done it yet..kill the friggin esp. Use the wheel method because it doesnt mess with your abs and such and just leave it off. The switch method is ok but it kills the abs as well.
Stock X with 3.21, 6 Speed.
I constantly find myself wishing for more gear. And if I am not wishing for that I am wishing for more rubber, which again makes me wish for more gear. It is a vicious cycle.
I find that the stock tires like to get packed with mud a turn into "slicks" if making a transition from mud to rocks with any type of incline...good luck.
x2 on that. Mud and water crossing I stop at the edge where I have some traction still and go down to 4LO. You still have momentum and the engine is a lot more efficient at keeping that momentum. It's always worked for me
ya ok like this guy http://www.youtube.com/watch?v=5Lugab0ehZM or this guy http://www.youtube.com/watch?v=JMOhV...eature=related 4 low when in doubt if your on slippery clay type mud
