JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
more capable with no lift
Old 10-28-2014 | 03:09 PM
  #41
knight1000's Avatar
Here are some pics of my 2012 JK Rubicon. I have flat flares with 285/75/17 TOYO MT. NO LIFT. It does great off-road. Now, I admit I don't wheel it "hard", but I have gone up some snow covered trails that nothing other then a good 4x4 was going to make. I got the Jeep for camping and it does great on all the trails Ive run and even the places where there were no trails.
ID:	581960Click image for larger version
ID:	581961Click image for larger version
Old 10-28-2014 | 04:47 PM
  #42
topher525's Avatar
Originally Posted by knight1000
Here are some pics of my 2012 JK Rubicon. I have flat flares with 285/75/17 TOYO MT. NO LIFT. It does great off-road. Now, I admit I don't wheel it "hard", but I have gone up some snow covered trails that nothing other then a good 4x4 was going to make. I got the Jeep for camping and it does great on all the trails Ive run and even the places where there were no trails. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=581960"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=581961"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=581962"/>
Do you get any rubbing at full lock? Or did you adjust the stops? I like the look and those are the same tire size I've been eye balling since I got my 14 JKUR
Old 10-29-2014 | 12:58 AM
  #43
GJeep's Avatar
"I hate how the steering geometry goes insane with even the smallest lifts"
That's a myth.
On my previous Jeep, I could change between 0" and 4" lift (it had air springs). With 4" it didn't behave any worse than with 0". Part of the good overall ride and handling quality was due to the air springs, and steering definitely didn't suffer.
The current JKUR, with 4" lift, behaved and steered well, no flaw vs stock.
Then, after adding the Full Traction CRC Link, the steering of the 4" lifted Jeep had improved and became much better than stock, as the typical (to live rear axles) need for constant little steering corrections is gone.
Originally Posted by holy_crap
I had a totally different experience with my 3.5" (actual) lift. With the 3.5", my front axle shifted to the driver side almost an inch until I added an adjustable track bar. I just don't see how going up 4" with the track bar remaining the same length could not affect the geometry. Hitting a bump with the axle shifted would make the Jeep want to sharply turn to one direction, not fun.
Obviously, when a 4" lift installation involves shortcuts and isn't properly done, there are negative consequences.
When properly done, the claim that - "I hate how the steering geometry goes insane with even the smallest lifts", is simply not true.
My suggestion to the original question which was "more capable without a lift" I would say that you need to cut the fenders or install flat fenders so you can fit 35" or 37" tires, install a snorkel if you are anticipating any high water, add a full set of skid plates or at least for the engine oil pan and transmission along with a good set of rock rails, and finally if you are going to add an aftermarket front bumper with a winch, you will want at the minimum a leveling kit.
x2
Old 10-29-2014 | 05:09 AM
  #44
knight1000's Avatar
Wheel spacers with stock wheels. No rub at full turn.
Old 10-29-2014 | 05:20 AM
  #45
black_14_jks's Avatar
I think for now im just gonna invest in some good skid plates
Old 10-29-2014 | 05:43 AM
  #46
auceny's Avatar
That has been my first priority. I self modded my front sway bar links to quick disconnect then put on an engine/tranny skid and now have an evap skid in the mail. I have a Willys edition so I already have stock rubicon rock sliders, rubicon tires, and factory limited slip rear diff. I would hate to pick a bad line and break the line running under my tranny or crush the evap canister and be stuck on a trail wishing I had bought the skids instead of lights or a BB or something else that didn't REALLY help me that much.
Old 10-29-2014 | 06:07 AM
  #47
TheDirtman's Avatar
A broken evap will not affect the jeep other then an engine light and relocation is better then skidding to save the weight. If you are going to be doing alot of rock I would do the oil pan, transmission, and a heavy duty cross member as they get toasted in the rocks. You will loose some ground clearacne with skids though and if you are dragging now it will be worse with skids.
Old 10-29-2014 | 07:45 AM
  #48
Yeah, ive got some federal mudders and ace rock rails already, lights are on the way. But I think an engine/tranny skid would be my best investment right now
Old 10-29-2014 | 11:36 AM
  #49
mikeJKUR's Avatar
Skid row off road makes a system that covers the exhaust loop on the 2012+ engines.
Old 10-29-2014 | 11:53 AM
  #50
Thatd be nice, does it require any cutting or drilling of anything to fit it?
Quick Reply: more capable with no lift
