more capable with no lift
#21
The TF 2.5 is more complete. The great thing you can get lift w/o shocks, extenders or their shocks. I have not that good comments on their shocks. I would get better shocks or just run yours with the extenders until you are ready to get new ones. The deal you found sounds like something worth checking up on though.
#22
For reference. Check out Project-JK. Read up on the write ups with different lifts and they are very informative.
#23
I've done some pretty good hill climbs without lockers. Faster is not always better but sometime it is. If you have the time to try the same climb a couple of times try varying your speed and angle if possible.
#24
As slow as possible as fast as necessary. .. unless a buddy calls you a pussy
#25
Ive lifted several vehicles ive owned in the past and have tossed around the idea of doing the same with my jk, but for now I have decided against it. I like the way it handles and I hate how the steering geometry goes insane with even the smallest lifts, and I love the fuel economy im currently getting. So, my question to you guys is: what can I do to make my jeep more offroad capable without a lift kit?
#28
So would it be reasonable to assume a 2 inch system wouldnt change handling or ride too adversely or would I need lca's and track bars?
#29
A 2" lift has minimal affect on handling due to geometry but it will be more top heavy and body roll will increase. There is no bolt on lift out there that is going to give you a better ride then stock. When people say that they are lying. It is just a matter of geometry. Most people that install lifts also install new bigger wider tires which increses track width and adds to stability. Many will also install new shocks that may help with ride quality.
#30
In the end, your rig. Whatever you do, research, buy and install what works for your intended purpose. Raising it will affect handling. I disagree with Dirtman on he better handling part. My stock suspension on my JKUR was a little sketchy on wash board roads. It handles better now. Higher center of gravity? Yes. But, I think we all know Fox has some of the best shocks out there and by far better than the stockers on any rig. And the spring rate I have, is cushier than the stock springs I pulled. As for geometry, I just made certain those axles were pushed out a bit more. No wandering, no tracking, and very, very little pull to the left.
I would lift again, but I also hit some solid 4x4 only rails. I think a vast majority, wouldn't even attempt many of the trails we have out here.
