JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Manual on a steep grade
Old 06-11-2008 | 05:59 PM
  #41
jeepcanoe's Avatar
Originally Posted by dick_burns
I find myself backing down steep hills and off rocks quite a bit due to my manual. Sometimes I need to brake and gas it at the same time when taking off from a stationary position when im in a hairy spot but I dont have enough feet, so I have to roll back down and start over again. Is there some sort of technique that I can use to help me out?? I had a hand throttle on my old Blazer and that made all the difference in the world. I was able to clutch, gas and brake at the same time. Is it even possible to have a hand throttle on a JK?
Dick burnslove the screen name. I use the right foot with the heel on the brake and the toes on the gas. The left foot works the clutch. Sometimes I use the hand brake.
On a side note I will be in Fairbanks the 1st week of august. What is the weather up there. Thanks for any info. in advanceme
Old 06-11-2008 | 07:31 PM
  #42
RedrockX's Avatar
use the hand brake....
thats why its there...
Old 08-11-2008 | 01:53 PM
  #43
labjeep's Avatar
I was just reading the Sept. 2008 issue of Four Wheeler and they have an article about that electronic hand throttle others had posted about. It's 3 pages about project 'con artist' and an install they did of this product. Sounds great and would solve the steep hill issue without riding the brake or clutch (OUCH!).
Old 08-17-2008 | 08:55 PM
  #44
w squared's Avatar
Originally Posted by dcblew
learn to use the clutch as a brake by letting the clutch out till your rpms start to drop let the brake off and the jeep will just sit there it won't roll back then pull at like normal little gas till she starts moving and let clutch out works better in 4 low but will work in 4 or 2 wheel drive
+1. I used this very technique a few times today while playing "tail gunner" on a group of newer jeepers ascending a cut line with lots of rock "stairs". If you "feel" your way out with the clutch, you'll know when you're clear to let off the break...probably even without looking at your tach once you've had some practice.
Quick Reply: Manual on a steep grade
