Manual on a steep grade
#31
learn to use the clutch as a brake by letting the clutch out till your rpms start to drop let the brake off and the jeep will just sit there it won't roll back then pull at like normal little gas till she starts moving and let clutch out works better in 4 low but will work in 4 or 2 wheel drive
That's a good way to keep yourself from rolling back into a Jaguar while starting off on a hill.. but it'll burn your clutch out fast on the trail.
#32
I think this MIGHT help. Looks like a nifty tool for situations like you are having.
http://www.northridge4x4.com/proddet...p?prod=RE-1000
The universal hand throttle is designed for use in Jeeps with a manual transmission. Unit mounts to gear shift lever for easy access and control. Works as an off-road cruise control for technical trail sections and is invaluable when simultaneous use of clutch brake and throttle is required. Kit includes all necessary parts to mount to throttle body or carb.
#33
All of these replies are really good advice, but my suggestion is that you learn all of them. I have used all of these in different situations.
The handbrake method works great, but remember that if the incline is too steep, and there is a risk of a backwards roll over, you don't want the rear brakes locked hard. You will need to be ready to release the rear fast to prevent a back flop.
With 33s and 4.10s i find the gear ratio not low enough and had to learn how to feather the thottle to keep from stalling. Even a little powerbraking can work to keep the engine from stalling, keep the speed down and keep the wheels turning. This engine also stalls easy and does not recover when it boggs down too much.
Heel toe comes in handly as well. Bottom line, all of these techniques take practice. The JK Wrangler manual is a little tricky compared to other manuals and takes some getting used to especially on tough trails.
What I did is went to my favorite moderate trail and tried different things. It was an experimental trip that resulted in lots of stalls. I may have looked like a rookie (which I was) for a day, but learned a ton that improved my skills and confidence greatly on the hard core obstacles.
Practice and experiment.
Have fun and be safe.
#35
#36
#38
I was wheeling up a steep hill and stalled while in 4lo. (3:21 Gears )
When trying to start the Jeep back up it just cranked and wouldn't turn over. I'd have to try several times b4 it starts to run. Anyone else experience this and what did you do?
#39
