Manual on a steep grade
#22
having only 3:21 gears, I stall allot on steep off-road inclines as well. I see you saying to start in 4lo without the clutch in and the gears in 1st gear. wont the Jeep lurch forward when starting with the gears in 1st and then stall all over again. Ive never started in 4lo in 1st gear and the clutch out. what really happens?
next time you're out, try it. it will blow you mind.
#23
#24
only if you're not on a steep section of trail or attempting to climb a big obstacle. in those situations, gears like those will still stall and even if they didn't, sometime you'll want a greater sense of control especially if you are in a precarious situation. but yes, ultimately, the idea is to get your foot off the clutch and let your jeep crawl all on its own.
#25
Couple good things to know.
If you are in 4 low you can crawl pretty well without throttle until you hit taller/steeper obstacles.
If you are in 4lo and do manage to stall it, your JK will start without the clutch.
I drive with 2 feet on the trails.. My left covers the brakes and my right on the skinny pedal. I Apply my throttle to keep her around 2000/2500 RPMS (depending on the severity of the obstacle). This puts me in a decent power/toque range for the JK.
How do you keep from beating the hell out of your rig you ask? I control my speed with my brakes. Once my throttle is where I want it for the obstacle I gradually lift my left foot and let the engine go to work.
The only time I touch my clutch is when I need to move to a higher gear between obstacles.
2 foot driving definately takes some getting used to, and it's REALLY fun when you get back on the highway and have to adjust again. (ask me how I know ) It might wear your brakes out faster too.. but hey, breakage and worn out parts = upgrade opportunity.
#26
I will try to get the hand brake tech down. That will probably help me alot.
I never stall on the road but some of the stuff I was doing last Tues while at hench mountain was nearly straight up when I stalled....... I was in 4 lo too.
On flat ground in 4 lo mine does move with out gas.... crawlin..... but up hill its a diff story. Probably cause my 3.21s I would like to be able to afford 4.10s at least - that would be nice.
What about that hand throttle, would that help me out since I have the suck gears?
#27
I dont know for sure because I have never drove a jk with 3.21s, but I would seem to think that with 3.21s it would be extra tough to master the hand-brake or the toe-heel techniques, but I dont think I should have a problem with my 4.10s and 4:1 low.
A hand throttle would be the easy way out, but I think we should both try to master these techniques anyways because you never know when you might need them. I would hate to sink a buddies truck at a boat launch just because I dont know how to handle the situation without a hand throttle.
#28
you need to use your hand brake. even before you start your climb, pull your hand brake a couple of clicks up (or more if necessary) and it will help control your speed while allowing you to give your Jeep more gas. if you end up stalling, do the following:
1. pull your hand brake all the way up.
2. put your transmission in 1st gear
3. hold your hand brake with your right hand, take your foot off the brake and then put it on the gas so that you can begin moving forward - if you start rolling back, the hand brake will help keep it to a minimal and enough so that you can focuse on moving forward.
4. with the hand brake still up, begin accellerating and let off your clutch slowly. when you feel your Jeep start to grab and move forward, slowly let off on the hand brake so that it is syncronized with the movement of your Jeep.
5. once you get going, release the hand brake all together.
it may take some getting used to but it does work and will keep you from burning out your clutch.
#29
Mark A. Smith's guide to safe, common sense, off-road driving tips says to keep your foot OFF the clutch. If you are on a steep hill and have to stop turn your key off. when you are ready to go again start your Jeep in gear with your foot OFF the clutch. It only works in 4lo, but if you are on a steep hill it should be in 4lo any ways.
Howdy
Howdy
#30
Howdy
Howdy
