JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
how deep can you go in water with a stock JK??
Old 07-30-2008 | 06:11 AM
jkkat's Avatar
I would think as long as you have doors on you couls make to the top if the tires as thats where most of the breathers end from the factory.
Old 07-30-2008 | 06:59 AM
4x4jkx's Avatar
As for your exhaust if you stall water will flow back up to the level it is outside your pipes. So if your right where your exhaust collector is your can bet that in just a little while the water inside the pipes will reach that level. If you start the Jeep up again you can suck water in through your exhaust. That initial crank of the crankshaft creates a vacuum action and pulls air from wherever it can.
Moral of the story... don't restart your Jeep when you're under water.
Old 07-30-2008 | 07:06 AM
WRAITHYJEEP's Avatar
water will come past door seals and flood interior
I have had mine past the front fender
water can and could come over hood and will come in via hvac system.
Old 07-30-2008 | 07:12 AM
jeff@zina.com's Avatar
30" according to Jeep (The Trail Rated badge is a minimum of 19" but the stock Wrangler can do more). Enough to get your feet wet if the doors are off. Naturally that's with no wake...
Jeff
Reference: http://www.carseek.com/reviews/jeep/2007-wrangler/
Old 07-30-2008 | 07:59 AM
Ge99ne's Avatar
Default How deep can you go IN water?
Oh you can go in water that's 20' deep. It's the getting out that's the problem. Jeeps number is certainly on the conservative side. That said, there are people out there who can break anything while inside of the prescribed limits. I've had mine mid grille with no issues. (and no water came through my door sills) Speed definately has an impact. I do my runs slowly, since I can't see what's underwater, I can't bring myself to hit runs at hydroplane speed. I had my old 88 cherokee nearly up to the hood on several occasions without taking on water. I'm surprized it wasn't floating the water was so deep. And this was a paved road.
Old 07-30-2008 | 08:04 AM
jkkat's Avatar
No water inside here.
Or here
Old 07-30-2008 | 08:37 AM
spartan99's Avatar
I did $500 worth of damage by mudding where my wheels only went about 1.5 -2 feet deep. Maybe I had too many rpm blasting too much mud and water into the my engine bay, but it's costing me and the warranty doesn't cover it. So, be careful with your stock JK if you're new to this, as am I. I wouldn't go in water w/o a lift and 33's and if you do keep the rpm down if you can.
Old 07-30-2008 | 03:07 PM
Big D2's Avatar
Stock Rubicon going for a swim..
http://www.youtube.com/watch?v=Y71GkrKsmWI
Old 07-30-2008 | 05:04 PM
SiliconTi's Avatar
I've had my Rubi up to the rock rails many times, no sweat. The only thing that leaked was a drain plug that does not seat correctly, so water leaked through it. 4Lo and let her creep.
Old 07-30-2008 | 05:28 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
There is NO vacuum affect thru the exhaust valve, it will never suck water in thru exhaust.
Quick Reply: how deep can you go in water with a stock JK??
