JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
D,1,or 2
Old 10-24-2013 | 07:35 PM
Steeperjeeper's Avatar
Default D,1,or 2
When you're taking your jeep out with an automatic transmission do you put it in drive,1,or 2. I always use drive but would 2 or 1 be better? Mostly mud and trails riding.
Old 10-25-2013 | 03:26 AM
Yankee's Avatar
I just leave it in Drive and turn off the Overdrive.
I turn off the ESP/traction control if in 4-hi.
Old 10-25-2013 | 04:54 AM
SKTN Rubi's Avatar
I have used 1 and 2 for big mountain decents to save my brakes if the road is so so and im in 2wd. Pretty sure the owners manual mentions something about engine using them this way actually.
Old 10-25-2013 | 02:08 PM
jk_sea's Avatar
It really depends on what you're doing. The goal is to minimize shifts and keep the engine and transmission circulating fluids so that so heat doesn't build up.
If you're crawling in 4-lo, you should lock out in 1st gear.
Old 10-25-2013 | 04:36 PM
familytime's Avatar
JK Forum Regional Rep
Trail driving 2 or depends on trail
Old 10-25-2013 | 04:43 PM
JKZinger's Avatar
I use them all depending on the size of the rocks,ledges and climbs/descents. I try to keep the RPMs around 2k
