JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Crossing water precautions?
Old 03-04-2014 | 02:39 AM
  #51
wcartwright77's Avatar
Having never attempted a crossing first hand, "generally"... IMO, would seem to be the correct word to use in describing water infiltration. There are a few factors to take into consideration....length of the crossing, strength of current, etc. Again, please re-read my initial statement and take everything I just said with a grain of salt! Lol, I'm a Floridian and we have almost zero "crossings" other then a swamp or two. Have fun!!
Old 03-04-2014 | 03:30 AM
  #52
Battlefrog21's Avatar
I've done quite a few water crossings and have had water several inches up the door. I have never had water creep into the cab. I would suggest (not sure if this was covered yet) that you relocate the front/rear diff breathers and transfer case breather if you plan on or may encounter deeper than normal puddles
Old 03-04-2014 | 04:14 AM
  #53
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
Originally Posted by ufgeek
Noob question:
If the factory doors are on the jeep, does water (generally) stay out of the cab? Assuming there is no tub damage that shows daylight
Is crossing generally safer with the inner flares still intact?
/geek
I have the plastic diamond plate sill guards, so a little water can get in. I'd say maybe a couple teaspoons at each door for a longer, deeper crossing. Really not a problem as long as I don't get stuck out there. If you don't have sill guards, that is a tight seal--you shouldn't have any leakage.
Quick Reply: Crossing water precautions?
