BLD vs Lockers?
In my experiences with BLD (which are admittedly only a few times on the trail), it definitely seemed to engage and stay engaged until I had both wheels back on the ground again. It did take a brief moment (maybe a half-second) for the computer to realize the imbalance and engage the BLD, but once engaged it was engaged.
In the last year I put on over 1000 miles thru med to difficult trails and while it is an impressive system it takes time to engage and when I had tires off the ground it would engage move forward and release. As well as surging on rocks to get moving. Again this is real world experience and not a book or marketing tool. But it hasnt let me down and has always got me thru things
Say a front and a rear wheel are spinning, and the front one gets traction, the rear one will stop spinning, too, causing the BLD to let go.
Nope not from that but under constant throttle and tire spinning. Read fourwheeler mag about Cherokee. They had same prob. Would get over rock with bld then bld would quit and jeep would lose traction and slide back down.
I mentioned heat above not to say that overheating brakes is a problem, but to explain where the energy was going (conservation of energy, a basic principal of physics). I run without lockers most of the time. However, I have been on obstacle on rare occasions where I wasn't able to get up it. The Jeep would slip and slide and just not go up. Turning on the lockers allowed it to go up. Notice I said up. Torque be damned, it is on steep climbs that the BLD will sometimes not quite make it. If you watched the video I just posted from Buckhorn on my YouTube channel (DigitalByDoiron), you'll see near the end me pulling a Toyota to jump start him. I swapped positions with an open JK Sport because he was barely able to negotiate the hill and felt he could never do it pulling another vehicle. I did it with ease.
Thanks, guys!
Okay, so steep, constant climbs are an area where BLD may not provide the same capabilities as a true locker. That's kind of what I was looking for. I'm thinking that in most cases that I'm likely to run into in Florida, lockers may not be a significant upgrade to my off-road performance, considering that I already have BLD and Trac-Loc. With 3.21 gears, a re-gearing to 4.88 is on my horizon (when I upgrade from 33s to 35s, probably), but I was trying to figure out if it made sense to spend the extra $$ at that time and install lockers.
Thanks, guys!
As for building your Jeep for where you live, I encourage people to build for where they hope to go. If Colorado or Moab are in your future, I'd say you're better off with lockers. But I ran both without for a long time until I could afford the mod.
