After wheeling maintenance????
More than likely...mud/sand/rock caught between your brake pad and brake rotor! Use a powerwasher and try to spray in at the caliper to see if you can loosen it up. If it grinds for more than a day take your tire off and check your pads and rotors for any abnormal wear and at this point you can give it a good cleaning!
You may want to check the bolts on your suspension also just to make sure nothing came loose from wheeling. Probably do not have to do this evewrytime but would be good to be done every few times depending on how hard you wheeled it.
i do all the above, and take a can of spray paint to cover up all the places i may have scrapped paint off the frame, skids, axles, etc, just to keep surface rust from becoming a bigger issue.
also a good way to clean underneith if you don't have time is put a sprinkler underneith the jeep to get a lot of the stuff off before you to through and wash it
When I get off the trail, I air back up, rinse the underside of the Jeep off paying special attention to all the parts that can move or have bolts in them. Depending on how much mud, I rinse off the engine as well, especially the radiator. Then I crawl underneath and check to make sure everything is there, nothing is broken, and everything is tight. If something is wrong, I try to fix it on the spot or decide if I should fix it at home. I top off the fluids if necessary and depending on where I was, drain and replace the diff fluid. After getting home, and the Jeep is all cleaned up, I do all the checks again.
