HELP Cranks no start, fuel pump turns on...
Hello, I put carb and choke fluid on the intake and turns on briefly for 20 seconds I press the gas pedal with no response turns off I guess after fluid is over. Throws 4 codes accelerator pedal sensor, MAP sensor, air temp sensor all circuit high and cylinder 4 misfire. Please please help...
![](https://www.jk-forum.com/forums/images/ranks/veteran_nationalguard.png)
Well, you are getting spark on the fluid. What engine, 3.6L or 3.8L When spraying the carb cleaner and you press on the gas does it change rpm or die immediately? Look up the fixes for the 3 sensors and see if there is a common cause fix.
good day and thank you for repliying my message. It's a 3.8L V6 2010 manual tranny. After applying the fluid it cannot be accelerated and dies within 10 to 15 seconds. Please help
