xsvi-6522 problem
Old 10-31-2007 | 03:44 AM
phil's Avatar
Default xsvi-6522 problem
Hey all
Installed my xsvi-6522 harness yesterday in my 08 wrangler x without infinity system. Connected to Sony cdx-gt610ui headunit. Initialized harness with power turned on for 30 seconds without radio being on per manufacturer instructions. Radio faceplate doesn't illuminate. Reset headunit under faceplate and could hear appropriate noise, but still no power to faceplate.
Any ideas?
I found out today that my headunit is being powered by the yellow (constant power) wire from the xsvi-6522 harness. Still nothing on the red (switched power) from the harness.
Thanks
Old 10-31-2007 | 07:00 PM
JackMac4's Avatar
Nobody with the harness can chime in? I don't have it so I can't help...
Old 11-05-2007 | 08:28 AM
freeswimmingfish's Avatar
I replaced my HU with a Sony, used that wire harness, see this thread:
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/hu-subwoofer-info-help-17159/
Are you saying that your red wire has no power on it? It should.
Yellow is constant, Red is accesory.
http://www.xplodsony.com/files/manua...ion_Manual.pdf
Old 11-05-2007 | 09:07 AM
oZmonKey's Avatar
I have a cdx-gt610ui sitting in a box under my desk at home.
Oh the troubles I had trying to incorporate it into my dash really caused me quite a bit of frustration. I tried the metra harness and had a different set of issues. In the end I gave up and am waiting for a pulled mygig to show up on ebay for cheap.
the cdx-gt610ui has been my favourite head unit ever owned, so it sucks that it's sitting in a box for now, i'm considering selling it.
Old 11-06-2007 | 04:07 AM
wayland1985's Avatar
As stated, the red wire should be hooked up per harness instructions.
Old 11-06-2007 | 12:32 PM
Mine worked great from the very beginning, check your connections and make sure it is wired properly. If all is good, return it for another one.
Old 11-16-2007 | 01:25 PM
phil's Avatar
Default xsvi-6522
Hey all,
Thanks to everyone for their help.
still not getting power on the red wire coming out of harness.
I am using the yellow wire to power radio, shutting on and off manually.
Looks like a defective harness.
