Work light(s) out back.
I'm looking to install a work light on top or top corner of the freedom top in back to provide some illumination if need be during the night (camping, tailgating, what have you).
1. Wondering if anyone has some suggestions/reviews as to a particular light for this application that has worked well for them?
2. Being a little drill-phobic, (especially through the hardtop) ideas for mounting solutions?
Thanks for any info. on the topic!
That's an intriguing project. When you get it put together please post up your solution. I would GUESS that you could use the windshield light bracks to the upper corners of the hard top, mount some flood lights of your choice and run the wires to the dash. I simple disconnect at the rear near the discount for the rear wiper would allow you to remove it easily. Good luck!
I've definitely already thought about a connection that disconnects easily for removing the top. I do like the thought about using the windshield brackets on the top corners to mount to. Any feedback on a light? Nothing crazy but enough to see what's happening within 10' or so from the back.
Attachment 108012Attachment 108013Attachment 108017
I used the 4" Hella work lights, wired to the reverse light to get me some additional light when backing up.
Basically the same idea you've got going on your rig but up high. I've been looking at the Hella work lights online (and I must say I'm super happy with Hella as they sent me a new driving lamp on the house when I broke mine accidentally taking it out of the box). I just wasn't sure as to the light output/spread they would provide. Was also looking at the Apollo series by KC.
I kinda did like the last post but I put the lights on/in the spare tire bracket. I just got some cheap ones from Wal-tucky and wired them to the reverse lights. It really helps when backing up at night. They are the single bolt type that were very easy to drill into the bracket and angle them downward to see.
Will a remote light work for you
GOLights offer a light that you can attach permanently or magnetically. This can be a multi purpose light for you. THEY WORK GREAT !
Mount Two Stainless Steel Plates using a silicon as you don't want to drill
Just mount one on top Center near windshield and mount another on the rear. The magnetic mount is strong and if you use the wireless remove you can adjust as needed outside of the vehicle. You may want to consider a battery saver that would protect your battery from going too low and NOT start for you!
The other advantage of the Golight is you can quickly attach when needed, so you won't have to worry about THEFT...
QUOTE=Heavy_D;1978822]Good idea. Might consider mounting one to my roof rack for camping and such.[/QUOTE]
