won't start after new marker light install
also checked if any diagnostic trouble codes came up... nothing.
battery is at 12.45v shouldn't be the issue since it's not even cranking.
another idea:
key security code got wiped from computer? (tried bothe keys - but don't think this I the issue since ive read that I should be able to start without a programmed key - though it will die shortly after)
Sometimes in situations like this we overlook the obvious. Have you checked your battery's voltage? Could be that you simply have a bad battery. I recently encountered a minor delay in starting that resembled the symptoms of a bad battery. Fortunately it was caused by a corroded positive terminal and not a bad battery.
Barring a bad battery or terminals, sounds like you burned out the TIPM or maybe even the WCM. If that is the case, the dealer will have to remove, install, and program a new unit for you. Hope that's not the case though.
yeah, I was thinking at this point it might be a bread board shorted somewhere :(. any ideas on how to confirm and maybe get a used one?
thx for the reply! unfortunately I checked the battery... multimeter says ~12.5v (where I expected it to be). I cleaned off the terminals, but they looked clean anyway.
Other members can correct me if I'm wrong, but accurate diagnosis of a bad WCM or TIPM can only be done with a Starscan tool. Some have reported that a faulty TIPM will cause all kinds of wacky behavior in the Jeep like the wipers working without being activated, dead or inaccurate instrument cluster, and/or other electrical ghosts to arise. Some have just had it go out and the results has been no start. A bad WCM will typically allow the Jeep to start for a few seconds and die or sound your alarm. But again, some have reported that it just failed and the Jeep wouldn't crank.
I know for sure that only a dealer can program either of these items. It's possible you could find a used part, but after installation, you still won't be able to start the Jeep until the dealer programs the Jeep to recognize the new part. Keep in mind most dealers won't agree to program a used part and will require that you allow them to install new or remanufactured Mopar parts prior to programming.
Good luck!
