Wirring auxilary stuff question
Ok, so far I have my Winch connected to my battery. I would like to install CB radio and some auxilary lights as well. Can I run all this stuff to the battery or do I have to do something else? sorry for the dumb question but I am electricly retarded.
Thanks Echo,
I know I will have to replace the battery at some point in time but since it is only 6 months old I would like to wait a little bit. I just wanted to make sure that it is safe to attach everything directly to the battery. Sounds like I will be fine and I should plan on udgrading the battery sometime in the next year.
The M9 fuse is power from fuse box under the hood. M9 fuse is ignition on power..... This runs to a distribution block that is behind the drivers side dash panel. This only lets power to the relays via the switches. It does not actually power the accessiories. From distribution block to each switch.
Another electrical dummy
