Wiring Windshield Light HELP!!!
Do you have a meter? If so, check for continuity with the fuse in the holder; remove the wire from the battery and switch, you ought to see a short or nearly 0 ohms, if it is open or infinite ohms, your fuse holder is faulty. remove/replace.
Find a spare terminal on the TIPM (Fuse panel) that is only on with the key in the run position for your switch power. You will only need a 5a fuse for this part of the circuit as a relay has very little load to it. This will keep you from draining your battery with the key off or in acc mode.
I'll go get my meter and check. You're saying fuse holder as in the fuse tap accessory Im using?
Attachment 495751
Just checked the fuse tap, theres no current coming out of it, but it is getting to the fuse itself.
EDIT: Gonna go check the inline fuses.
Attachment 495751
in which case you're tapping off the output side of the fuse and running an additional cartridge fuse in-line to the switch.
Okay so I just took a look at the inline cartridge that connects the fusebox to the switch. Earlier when you said for me to hook it from battery to switch, the switch still didnt have power. Well I took the blown fuse out the cartridge and tested it to find that it has power when directly connected to the battery but not the fusebox. The current isn't making it from one end of the cartridge to the other( that goes to the switch). I tried just touching the 2 metal ends of the cartridge together, and it showed it was powering the switch but the lights and nothing else came on. I have another fuse I stuck in the cartridge (its a much larger rating), and the current didn't travel through it either. I'm really lost now.
Attachment 495765
at no point should you have an open with the fuse in place if you are testing this portion of the circuit.
Attachment 495764
Attachment 495764
I assuming that you checked and double checked your grounds?
