Wiring up LoD rear lights, melting a wire! Help!
Old 02-21-2010 | 05:05 PM
highoctane's Avatar
Originally Posted by JK-Ford
Well I did not say that you have the bet set-up. I personaly recomend using a relay for higher loads. Just feal your switch when the lights are on. They will probably feal warm. And you just seen the results of a bad connection. Now would you rather have that in the cab with you or under the hood. But, your problem is from a bad connection. Not the lack of a relay.
New fuse fixed it. The cheap autozone offroad light wiring kit had a plastic fuse housing that is rated for 5A. The two LoD rear lights are 55w. I figure 55*2/12 would get me the amperage I need so a 10A should do it. New fuse is 30A rated with a 10A fuse in it. Ill prob rewire it this coming weekend with a relay. I only use these lights for brighter bacjup lights when I need them, so they arent used for more than a minute tops. I left them on for close to 15 min to test everything and didnt feel like the switch was hot, or even warm.
Old 03-02-2010 | 10:00 PM
PCHSahara's Avatar
I'm looking to wire up my lod rear bumper lights this weekend. I'm using the lights / wiring that came with it, except a daystar switch instead of the included switch.
It looks like i will definitely need to solder some wire to the lights red/power wire as its not long enough to reach the dash/switch.
Do I need anything else? A wiring harness, a relay?
According the the various installs I have seen, the wire is just running insde along the side under the carpet.. do I need to protect it in any way?
Thx in advance!
