Wiring these to the tail lights
Just picked these up yesterday.
I want to mount them partway down the side of my JK as marker/turn signals. Would I hook them up similar to the front marker light mod? I was thinking I'd go to the tail lights since they will be closer to the rear than the front.
There is only 2 wires coming from each light. A ground and a hot. It almost seems too easy.
Most things sound easy. And this mod may be? But you have to consider the added load. The JK-computer knows what the load is suposed to be. The lights will not work at all if the load changes to much.
