Wiring Options & Ideas for mounting Hella Matador Work Light
I'm going to mount a Hella Matador work light on the back of my jeep. I'm thinking of a few different mounting locations (either using a RR light tab attached to the top or side bar from the rack, or possibly fabbing a bracket off the tire carrier, or mounting it directly on the back of the hardtop using a steel back plate on the inside of the top to give it strength--this would include quick disconnect wires for taking the top off).
For wiring, I'm also thinking of a few ideas: either mounting a switch on or near the subwoofer housing since I'll be in the back most of the time I want to use it, or adding the switch next to my other switches on the dash or A-pillar.
Since I already have an extra dedicated reverse light, I was just going to use this as a work light and run the power directly off the battery--or is there a better power option back there that I'm not thinking of?
Any constructive thoughts and input would be welcome (especially from ronjenx).
Thanks,
John
Thanks,
John
