wiring off road mirror lights
So i have been reading around these forums for the past year or so and have found every question i needed answered however I cannot seem to find this one.
The problem I'm having is i Just ordered some new mirror housings with built in led running lights and built in turn signals however I'm running into an issue with wiring. I can figure out where to run the ground and running lights but as for the turn signals idk if there is any tap in the door wiring harness or how about i can run it so i can easily take my door off without a wire hanging stuck connected running through the firewall. The only reasonable solution i have thought of is putting a separate easy disconnect for the mirrors. however I'm just wondering if there would be some sort of easier place to connect my blinker wire from the mirror to my blinkers up front or where that wire comes into to connect to my turn stalk possibly
Thanks for any help much appreciated
