Wiring a Map light
Wiring a Map light
Has anyone wired in a map light on the front windshield at the top center? I was thinking it would be nice to have a little extra light in the front seats. I found this on a quick amazon search.
http://www.amazon.com/Light-WHITE-Un...rds=map+lights
I was thinking I could pull power from somewhere behind the dash or even the light on the rollbar and then wire in a switch on the drivers side pillar.
I know it's not necessary, but might turn out to be useful.
I have been considering the same thing until recently when I was looking through one of the many parts catalogs and saw a replacement rear view mirror made by CIPA with map lights built in. In the catalog it was $50. I just did a quick search on Amazon and found it for $35 with free shipping.
Totally worth it...
Amazon.com: CIPA 36000 10" Day/Night Mirror w/Map Lights: Automotive
EDIT: It will totally make the wife happy...
Totally worth it...
I like the mirror with the lights too. I guess you'd still have to get power from somewhere else though, and have a small wire(s) running down into the mirror...it is tempting though. Let me know if you get one and install it.
I had an 07' JK. Went to a local "You pull" auto salvage yard and got a rear view mirror w/ maplights off an Oldsmobile for $10. It slipped right on the mount glued to the windshield. I wired it to the domelight. Looked totally stock. I'm looking to do the same thing on my 12' JKU.
I just did this the wires are on the passenger side floor board yellow /yellow white/ground is right there as well just use some trailer wiring as its already grouped and color coded really easy got mine from a camaro
Quadratec sells a magnetic LED map light by Rugged Ridge for around $10. I've had it 4years placed on the front windshield top center where the metal loop is. The magnet sticks over all terrain, and the LED is bright and with barely any power draw I haven't needed to replace the batteries since bought it. Recommended !
