Wiring and l.o.c question 12'jk
I have a '12 jk w/ infinity system. Could anyone help me find the wire diagram for the infinity amp. Im going to bypass the infinity amp threw l.o.c's to my new 4-chnnl amp. Also im running a mono amp for my sub, should i have l.o.c on that also?
Thanks
Thanks
Have a look army thread here regarding this exact thing. Any ideas what the issue is? I have a 4 channel JL Audio AMP with 4 new JL Audio speakers and left the SUB stock.
http://www.youtube.com/watch?v=riblu...ature=youtu.be
Speaker Wires from Head Unit for Rears
Is the problem when you fade in and fade out from what i could tell from the video? Did you just swap the jl speakers out with the stock speakers and keep the factory wires?
[attach=config]278474[/attach] you can not simply bypass the infinity amp with a loc because it uses a can buss system to control volume, and other parameters. There are modules that will serve this function which are a little more pricey. You could run your loc for your 4 channel amp off the front speakers, but i think you would have to run off the dash speakers, and the tweeters. Not sure if you have the factory sub. I used a loc off my factory sub ( and kept it ) and it works great. The first loc i used would not work on the sub because of how much power it puts out. I bought a high power unit and its all good now.
Well the AMP is now under the passenger seat so I suspect the installer ran NEW wires. I have pictures of it here. Attachment 278490Attachment 278491
