wiring kc spots with factory fog lights switch
hi there can some one guide me to a write-up or a wiring diagram,
of wiring the kc spotlight switch so that they can be turned on when i switch on the factory fog lights? and if its even possible
i looked every where and i didnt find any
i have two kc day lighters 130w spots mounted on the windshield
u want them to turn on when just your fogs are in? I just did this, sort of. Cut the fog light wires, there's a white for positive, black for negative I believe. Splice in your power wire from kc light in with your fog light power wires. do the same for your black ground wires. I cut my fog wires and decided to just run the straight to the led fog/daytime running lights.
on a side note, I just figured out you can turn on only ur fogs without the headlights on by going one click up on your light knob and pulling out on the knob. I knew you could do that with the headlights on but for some reason never tried running just the foglights alone
yeah i know, i tried to turn them on in fog once couldnt see shit, but we dont get alot of fog over here maybe once or twice a year i use them when im offroad to get some light on the sides i just want them to be turned on with the same fog switch behind the steering wheel i know nothing about car wiring so im disparate for the help
You have to use a relay. The factory fog light circuit is not rated to handle 130 watt lights.
You can use the factory fog circuit as the trigger to switch the relay off/on.
Here is a simple wiring diagram:
Attachment 448574
Attachment 448574
