Wiring interior switches!
Old 03-11-2015 | 12:39 PM
Razerv3c1's Avatar
Default Wiring interior switches!
Hey everyone need help, where does everyone run the wires from the battery/fuse box into the vehicle? I'm trying to find a place through my firewall but can't! Pics or anything would be greatly appreciated!!! Thanks!
Old 03-11-2015 | 12:44 PM
mhockey9090's Avatar
Vet Army
Theres an access hole in the driver side firewall ( just poke through it with a screw driver and then run the wires ) and heres a thread for the passenger side. The passenger side if a different location than the driver.
https://www.jk-forum.com/forums/jk-w...hole-150674/#b
Old 03-11-2015 | 12:48 PM
Allen34's Avatar
On my 08, there is a hole that goes through the dash on the upper passenger side of the dash. If you open that panel on the end of the dash, you'll see it. Its filled with foam. Straighten out a wire hanger and you can poke right through it. It will lead wires right to your battery.
Allen34's Avatar
What he said. I type slowly.
Old 03-11-2015 | 02:04 PM
14Sport's Avatar
If you don't want to use the easy access behind the dash side panels holes, then peruse the instructions for the sPod. They have behind dash access points for both manuals and autos.
http://www.4x4spod.com/v/vspfiles/as..._2012-2015.pdf
