Which wire?
Which wire?
I am looking to tap into the power wire from the horn switch. Does anyone have the color and tracer for power to the horn from the horn switch?
I would like to tap into before it goes through the firewall to the engine bay.
I don't think that this is a good idea. That wire will have a communication signal on it. Not 12 volts.
Essentially, I am installing an aftermarket air horn. I would like to use the stock horn switch to activate the air valve for the horns.
I would mount everything, then just make some jumpers. Disconnect the wires from the stock horn and connect them to the air horn using the long jumpers you make. Then just press the horn like you would normally. If it works, it's a go. If not, switch them. the re try.
I would use a single throw toggle in between the air valve and the horn switch. When power is shunted, the air valve will not engage and the stock horn will. When power is sent through, the air valve is activated along with the stock horn
Although I'm pretty sure this would work. I'm looking to still be able to use the stock horn.
Thanks a bunch everyone.
horn wiring
Yeah, but when you want to use the air horn, will you have time to flip a switch too?
I have an idea a little ways down on my 'to do' list: get an air horn, and trigger the air horn relay, through a second relay, which feeds a signal from the regular horn, and is triggered by the brake lights. Thus, you normally get just the regular horn, UNLESS you are on the brakes and hit the horn at the same time - then you get BOTH horns!
