Windshield lights - Show me what you got
KC 8" Slimline long range 150 watt on Mopar brackets
No switch. Direct to my Highbeams
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I've got the same setup. Here are pics:
Here's the hole I used to get past the firewall...simply poke through the aluminum foil looking hole...I used a skewer, taped the wires to the end and poked it through.
This is the drivers side panel taken off. Just pulled from the top and out it came.
The switch looks factory! I placed it farther left to leave room to the right for more switches in case I install some KC's on my bumper.[/QUOTE]
Why do your lights look more upright versus clackey's is more leaning out and away form the pillar ifits the same setup???[/QUOTE]
I have the Mopar bracket. It mounts the lights down and out away from the windshield. Less obstructed.
Yeah, sorry, I was referring to the original question, not Clackey's setup. I do like the Mopar ones better, way more expensive but that's Mopar for you. I've noticed you have to bend the radio antenna around the lights though with those.
I like the bent look too! looks good! I love the windshield lights too, I just wish I could talk my fiance into them... she really hates them for some reason, I wanted to put them on her TJ too, but she wouldnt let me then either...
Sorry to hijack this thread but I was just looking through it and noticed that Clackey's jeep has nipple rings. Are those suppose to be some sort of recovery loop? Oh, thats right, you wanted your jeep to have a set of nipple rings just like you have? At least now you have a place to put your keys.
