Winch wiring question
your winch at full draw is 482 amps, your going to need a fuse to handle that load+. If your worried about shorts I would just use the solenoid so you can control power to the winch. Otherwise per Warn instructions go straight to the battery. Since your cable is short I would use the solenoid like others have said.
Just so I'm clear, electrical isn't my strong point, the disconnect unit somebody already posted is a solenoid, correct?
Yes.. I was. Thank you. One more question. Bought the winch used n the positive lead has wire loom on it but the negative does not. Should they both have it or is it just more important on the positive one? Thanks again for all the input...
I have no idea what it is rated either. I couldn't find that answer. I just took a leap of faith that it is a Warn and should work. I haven't had to use my winch. I did spool it out about 20' to test it after install and it worked fine. I only get to wheel once a year on vacation and I haven't got myself into a situation where I needed it yet, so I guess the jury is still out on how good it is. If I used my winch a lot I would fuse it. It's better to err on the side of safety than not. But the way it is wired from the battery to the solenoid is so low risk it isn't worth it to me.
Power wire shorting to ground is no bueno. Ground wire shorting the ground isn't as bad. That said, covered both of mine.
OK while there was a little back n forth on this thread, and all good points BTW, I think I'm gonna go with a fuse. Oh and I'm gonna loom that negative lead just in case...lol. Thanks everyone for your input!!
