Winch Install: Battery or winch issue?
Old 12-29-2011, 03:13 AM
Deere_Jeep's Avatar
Default Winch Install: Battery or winch issue?
Finished install on my XRC10 winch last night. Everything went well. Started the Jeep and began to spool up the line. Everythings seemed fine except the winch was slow and whining a bit. However there were bursts of speed. Ultimately with about 20 feet to go. I hit the remote and all the lights inside went dark, not winch but you could hear the solenoid clicking. Let the Jeep idle for probably 45 minutes. Went back out and everything worked.
-Winch said was 650CCA stock battery is 600. I keep reading about folks using their stock battery so I'm guessing they have 600 too.
Is it reasonable that under no winching load that I would pull down the battery that far spooling the line?
Old 12-29-2011, 03:24 AM
JK-Ford's Avatar
The battery shouldn't even blink under "no Load" condition. Make sure that you have good connections.
Old 12-29-2011, 03:31 AM
OH9JK's Avatar
Are you using the original battery that came from the factory?
Old 12-29-2011, 03:33 AM
Watercop's Avatar
Is it the original battery ?? If so it may just be wore out. Maybe time for a late Christmas present.
Old 12-29-2011, 03:34 AM
Deere_Jeep's Avatar
Thanks for the advice. I know I'm good on the battery side, double checked that. I'm wondering if i messed up the winch side. I recall there being
nut, lock nut, washer, wire. I put on it this order. I'm wondering if I should have done. nut, lock nut, wire, washer (Against stud). Would you really need a washer on the stud side of the winch to help conduct electricity?
Old 12-29-2011, 03:35 AM
Deere_Jeep's Avatar
Yes stock battery '08 39000 miles.
Old 12-29-2011, 03:44 AM
ShakyJake's Avatar
Whoa...there's your problem. If not now, real soon. Ticking time bomb. You want capacity in excess of winch draw.
Old 12-29-2011, 03:45 AM
Deere_Jeep's Avatar
Here is the connection on the winch side I talked about.
Old 12-29-2011, 04:20 AM
clewis7951's Avatar
Below is how I did mine...without issue.
I'd double check all your connections. Make sure your ground is good.
Old 12-29-2011, 04:24 AM
OH9JK's Avatar
Your connection looks fine. I would get the battery load tested...local Autozone or Advance should do for free.
Quick Reply: Winch Install: Battery or winch issue?
