Will flickering hid damage anything?
Old 09-27-2011 | 04:22 PM
Kojack's Avatar
Default Will flickering hid damage anything?
I'm getting sick of my hids in my jeep. Will the flickering damage anything?
Old 09-27-2011 | 05:00 PM
JK-Ford's Avatar
Yep, The relays, the ballasts and the lamps.
Old 09-28-2011 | 02:43 AM
Kojack's Avatar
I have had it in the garage 3 times trying to wire up a relay system to fix it and they still do it.
Hid while providing great light are not worth the pain in the ass.
Old 09-28-2011 | 02:50 AM
Hskr4x4's Avatar
There are other brands that won't flicker.. FYI, when you hit a decent bump in road and those lights are flickering, one if not both will go out then they are basically shot
Old 09-28-2011 | 05:39 AM
Kojack's Avatar
Can you elaborate on what brands dont, is there any plug and play HID bixenon systems? I have the lows working, drl is flickering and High beam flickering.
I love my HID, my 2 requirements now are no flickering and 4300k temp...
Old 09-28-2011 | 10:26 AM
ca412686's Avatar
Did you put a cap and diode in? I had to do that with my old Ford Edge in order to run the DRL's.
Old 09-28-2011 | 11:03 AM
IndyChavez's Avatar
Go on eBay and buy a pair of capacitors. Its plug a and play.
Old 09-28-2011 | 11:04 AM
dogsonparade's Avatar
Have you checked your ground? After installing mine-- they kept flickering when hitting bumps. I thought maybe they were cheap junk. After a careful inspection I found it was installer error. I didn't tighten the nut on the ground. I would go back and check everything- the ground first.
Old 09-28-2011 | 11:45 AM
Vladimer's Avatar
DDM has a plug and play bixenon kit. I tossed it in my 08, HI/LOW. Its dirt cheap and available in a variety of temperatures. I got the 4300k and love it. I used the procal unit to move my daytime running lights to my indicators. You can turn it off completely but being in Canada I would rather have it semi legal. The procal allows you to move it to the fog lights as well but since I have HID's in my fog lights I cannot have them running at half voltage so the indicators were the only option short of having the DRL off completely.
I've read of a few things on the forums to get the HID's running with the DRL and not flicker but it was just simply frustrating, I also didn't want them running all day through daylight hours either so eventually just got the procal. Plugged it in and withing 3 seconds my horn beeped and my DRL/HID problems went away
Old 09-29-2011 | 10:54 AM
Kojack's Avatar
They have them just using the plug for ground. I may have to ground to chasis.
