Why does my cobra cb radio reset my dash lights and trigger the washer blades and kil
#21
I have a 10g wire from my battery to a homemade relay fuse block mounted under the glove box. The wire goes through the fire wall at that little hole next to the door jam
#23
#24
Before you start tearing everything apart try running a ground wire from your antenna mount to a good ground on the body or chassis. I think you are depending on a good ground to travel through the hinges on the rear gate and you aren't getting a good ground. May not be the problem but it is a simple and quick test.
