why do fog lights go off when high beams are turned on?
Old 10-24-2008, 01:24 PM
  #21
Cruiser's Avatar
Wire in a seperate set of driving lights,, the ones that come from factory are wired thru your control module/computor.. If you hook up the wrong thing to the wrong thing you might be buying some very expensive things,,,
So do yourself a favor,, buy some e-code euro headlights with the h-4 conversion. If that isnt enough then go with HID's,, as the stock len's are so bad you wont get squat out of them with the HID's that you would with real len's.. And if you had good high beams you wouldnt need to worry about more light when high beams are on..
Good luck
Check out Hella E-codes.. cheaper than cibies and the rally car drivers swear by them..
Old 10-27-2008, 07:32 PM
  #22
d0wnShifT's Avatar
Originally Posted by jrubicon
Can we rephrase the original question?
Lets say, there are no rules about lights, etc. Whatever mod we do is our reponsibility...
with that said, anyone know how to mod our lights so that, the Fogs can be on, while the Regular headlights are off???
thanks
You can run fogs on and headlights off in your Jeep now. You just need the parking lights on and pull out on the switch for the fogs.
Now if you're talking about running high beams and fogs... i'd like to see a wiring diagram if anyone has a good write up.
Old 02-02-2009, 05:42 PM
  #23
johnnyd's Avatar
See: https://www.jk-forum.com/forums/show...07&postcount=3
Quick Reply: why do fog lights go off when high beams are turned on?
