why do fog lights go off when high beams are turned on?
#21
Wire in a seperate set of driving lights,, the ones that come from factory are wired thru your control module/computor.. If you hook up the wrong thing to the wrong thing you might be buying some very expensive things,,,
So do yourself a favor,, buy some e-code euro headlights with the h-4 conversion. If that isnt enough then go with HID's,, as the stock len's are so bad you wont get squat out of them with the HID's that you would with real len's.. And if you had good high beams you wouldnt need to worry about more light when high beams are on..
Good luck
Check out Hella E-codes.. cheaper than cibies and the rally car drivers swear by them..
Good luck
#22
Now if you're talking about running high beams and fogs... i'd like to see a wiring diagram if anyone has a good write up.
