Whirring noise while driving
Whirring noise through radio while driving
I bought a used 2012 JKUR a couple years ago. Im getting a humming or whirring noise with acceleration. It started right after I installed an ARB single compressor and Spod with some lights. If I let off the throttle and cruise it stops. If I barely mash the gas pedal it comes right back. Its what I consider fairly loud. I can hear it over the normal radio (so I blast it) wind, and off-road tires humming. I’ve heard this could be related to regearing which would not be the case with my car, gearing stock. I’ve heard possible causes are the fuse behind radio or alternator or starter. After noise had been there for a while I upgraded from OE to an Apple car play radio (U connect is crap) and installed a CB but the issue was there before the radio add. I had alternator and starter checked and they say it’s strong. I did run spod and compressor ground to battery along firewall and maybe that is cause? Should I ground spod to chassis? I did disconnect spod and compressor for a week and noise still there.
any input appreciated!
Adding another ground would not hurt; however, you grounded direct to the battery. Where did you locate the ARB Compressor & SPOD.. Check all the mounting areas, look for engine torque movement creating a contact area. Just a guess.
