What's next
What's next
Ok I ordered the kicker 6.5 speaker upgrade for the sound bar and the front. I have the 430n with alpine sub. I don't wat to go to crazy but my sub blows. Do I get the kicker cvr82 and just plug and play or do I get the sub and the replacement kicker amp? Not a stereo guy so don't know alot about it/
I just installed this:
Its a powered 12" sub, super easy to install yourself, running wires is the most difficult. I've measured SPL levels(with a rockford app) above 100db with a lot of room to go higher but i'm not into ripping my ear drums so this setup kills it. I have my remote level set to about 25% and it sounds magical.
As a reference: 85db spl is acceptable, but will cause damage over time, permanent damage occurs at 120db, human pain threshold is 130db.
Are you putting and amp to the fronts?
Ah... Well u could do this:
https://www.jk-forum.com/forums/jk-w...losure-231647/
You mentioned before the kicker upgrade thing in the stock enclosure which could be good, but this guy says not worth it:
https://www.jk-forum.com/forums/jk-e...nstall-214817/
What about upgrading your amp first?
