Whats better? Flood Or Spot lights? LED.
Old 11-20-2012, 01:13 PM
Momikey's Avatar
Default Whats better? Flood Or Spot lights? LED.
So what lights are better the flood light or the spot light. I am getting LEDs most likely with the windshield mounts one on each side of window and maybe a 50" across the top of the window later.
Old 11-20-2012, 01:20 PM
owntmeal4life's Avatar
Well spots are just beams and floods are well wide spread less distance from what I understand
Old 11-20-2012, 01:57 PM
swaite3's Avatar
If you get the 50" you will need nothing else. I have a 40" led that has both floods and spots built in and it's like turning the sun on. If you will plan on getting the bracket lights I would go with the floods if they are for the trail and spots of you plan on using them on back country roads
Below first pic is my stock lights second is the 40" led with both flood and spots built in
ID:	390637   Click image for larger version
Old 11-20-2012, 02:59 PM
Momikey's Avatar
Cool thanks. Ya I forgot you can get both on one light.
Old 11-20-2012, 03:53 PM
JK-Ford's Avatar
This is an open-ended question. Floods are best when used as Floods. And Spot Lights are best when used for Spot Lights.
Old 11-20-2012, 07:00 PM
flienlow's Avatar
No way, I want a vaporizing wave motion gun!
Old 11-20-2012, 07:01 PM
Momikey's Avatar
Well if you can only afford one or the other which one would be the best. Is that a better way to put it? Lol. But I have learned you can get both in one light so all is good.
Old 11-20-2012, 07:19 PM
keithvegas's Avatar
If you want them on the windshield I would get spots. Floods will reflect off the hood too much. If you get floods you would want them in front of the hood.
Old 11-20-2012, 07:21 PM
Ryan0260's Avatar
X2. Go with spots or long range
Old 11-20-2012, 07:36 PM
SBEII's Avatar
X3 especially if you have factory fogs. I had floods for about a month before buying some long range lights.
Quick Reply: Whats better? Flood Or Spot lights? LED.
